1991 Mercedes Benz 190e noise
1991 MERCEDES BENZ 190E
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
190ENY
there seems to be a squicking sound coming from my foward driver side wheel well. noise happeneds when i turn the wheel or if i push down on the car. wondering what it could be
Feb 4, 2009 at 11:42 AM
GFIMOTORCARS
  • 673 POSTS
This is more than likely a worn suspension bushing. The side that squeeks is probably your culprit. Check the lower control arm bushings for cracking and excessive wear.
Feb 19, 2009 at 5:22 PM
GERRYT123
i had a noise like that. It was the lower ball joint. I bought an aerosol can of GREASE. Then I cut a small hole in the boot above the joint and filled it with grease using the small plastic tube you get with the aerosol. It has to be repeated periodically
Apr 15, 2009 at 8:51 AM
