1989 Mercedes Benz 190e ALDL connector
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFF E
I'm a GM master tech. On this MB, the round underhood connector on driverside I assume is the ECM connector.Because I don't have the right cable ,what can I do to just flash trouble codes? Like connect which terminals on the aldl?
Nov 6, 2008 at 8:31 AM
THIS IS MIKE
  • 686 POSTS
An on-board test connection with push button and light emitting diodes is locate on left, rear engine compartment firewall. To enter self-diagnostics, turn ignition on and press diagnostic connector push button No 2, for 2-4 seconds. Impulse readout will commence flashing code sequence. Codes may also be retrieved through use of an impulse counter.
Nov 10, 2008 at 6:44 AM
