1988 Mercedes Benz 190e ignition key
146,000 MILES • 4 CYL • 2WD • AUTOMATIC
LEMUEL JOSEY
are my keys to worn to start my car all of a sudden the ignition wont turn over at all its like the tummblers are stuck what can i do to fix this problem
Feb 15, 2010 at 1:35 AM
OLDCAMERON
try using some white lithuim it is like wd 40 but will vnot ware out or build up .Or yourtumblers are waring out then you will have to buy a new switch from dealer or after market .Not bad to install have to take thecover of the steering call. off key has to be in the unlocked poss.unplugwith some type like paper clip in the two hole pulls out you can have it checked out they will tell youif they are.New a couple hun. dollars but your new key might not work on doors because the doors are worn with key .That happened to me
Mar 18, 2010 at 7:55 AM
