1988 Mercedes Benz 190e
163,000 MILES • 6 CYL • 2WD • AUTOMATIC
MOORECAT2009
I started having problems a few months back with Transmission slipping or not engaging into 2nd gear, I changed tranny fluid and filter yesterday and read wheer the transmission and converter hold somewhere between 6-7 quarts of tranny fluid, my question is i changed fluid and filter out about yr ago and had some occuring problems with shifting or slipping and my question is how many of the 7 quarts does the converter hold since both times i removed tranny pan and changed fluid and filter i only added 3 quartsand keep getting inaccurate readings on the dipstick.. some people are telling me i am way low of fluid since it will not shoft after 1st gr.. now ehen i leave it shifts and nerve shifts into 2nd bu RPM's climb till i remove foot from accelerator??
Jun 7, 2009 at 7:01 AM
ZACKMAN
  • 4,202 POSTS
Between the torque converter, radiator and transmission line, they hold about 2 - 2.5 quarts. I can almost promise you that you were low to begin with when you replace the fluid the first time.
I just serviced an 89 260E a few weeks ago, I had to add 4.5 quarts before it shifted smoothly. Can't really use the dipstick level. It is not accurate until the fluid is at running temp.
Jun 7, 2009 at 5:38 PM
