1987 Mercedes Benz 190e miss fire
1987 MERCEDES BENZ 190E
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
TRUEBLUE93535
idle is unstable and turns off when i make a stop
in drive
and also when idling, rpms fluctuate up and down sligthly some times turns off
Dec 31, 2008 at 2:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
It sounds like you have a faulty Idle Air Control Valve (IAC Valve). Should be located on the throttle body.
Need replacement instructions? Just ask and you shall receive!
Hope this helps..
Thanks for using 2carpros.com!
Dec 31, 2008 at 3:21 PM
