1986 Mercedes Benz 190e HORN
175,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROMEII
MY HORN DOES NOT WORK, CHECK OUT SWITCH IN STEERING COLUMN ,IT IS OK PLEASE ADVISE
Apr 8, 2009 at 8:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
Inspect horn fuse #11 8 Amp fuse in fuse box. If OK, supply 12 volt power directly to horn. If horn blows then inspect wiring of horn circuit. If horn does not blow then replace faulty horn.
Thanks for using 2CarPros.com!
Apr 8, 2009 at 10:57 AM
