my fuel gague fluctuates/flickers from time to time. is it the gauge that's faulty and should be replaced or is it some other situation?
Jul 6, 2009 at 1:10 PM
BUDDYCRAIGG
✓ASE Certified Mechanic
that could be a problem with the gauge.
a problem with the sending unit.
or a dirty electrical connection between the two.
does it seem to do it at about the same place on the gauge, or is it totally random?
Jul 6, 2009 at 10:44 PM
PINTO1212
MEMBER
about the same place. between 3/4's and 1/4 full. my manual shows how to remove thru the trunk and unscrew. easy to clean or is purchasing a new one better idea? or any suggestions.. thanks craig! phil
Jul 7, 2009 at 12:37 PM
BUDDYCRAIGG
with the age of your car, it could very well be a varnish build up on the sending unit.
I am not familiar with what yours looks like, but i have cleaned a few from various cars with good results.
Jul 7, 2009 at 5:32 PM
PINTO1212
MEMBER
little dense here. sending unit is what i unscrew via trunk. so i could remove by unscrewing and then clean it?
Jul 7, 2009 at 5:35 PM
BUDDYCRAIGG
yep, it's in the tank.
some cars, if you're lucky, have an access cover in the trunk. Other wise the fuel tank has to be removed from the car.
I would try cleaning it before I bought a new one.
I like to save money whenever possible.
Jul 7, 2009 at 5:51 PM
