1982 Mercedes Benz 190e
HEATH111
Engine Mechanical problem
1982 Mercedes Benz 190e 6 cyl Two Wheel Drive Automatic
wot start got good spark
Jun 17, 2009 at 9:51 PM
  • 31,937 POSTS
HI there, check fuel pump pressure first and if that is ok, the problem will problem be in the injection system, report back on the results of the fuel pump test.
Mark (mhpautos)
Jun 17, 2009 at 10:14 PM
HEATH111
hi there i can here the fuel pump and there is fuel getting to the fuel injector distibuatior.but not cuming out of the fuel distrbuator thingy with pressure dont have any thing 2 test fuel pump pressure but we thought it was the EHA fuel valve regulator and we replaced it with a second hand 1 with no luck[quote:b45806cff8="mhpautos"]HI there, check fuel pump pressure first and if that is ok, the problem will problem be in the injection system, report back on the results of the fuel pump test.
Mark (mhpautos)[/quote:b45806cff8]
Jun 17, 2009 at 11:00 PM
HEATH111
its a 1992 not 82
Jun 17, 2009 at 11:08 PM
