Mega fuse?
200 MILES • V8 • 2WD • MANUAL
TSHROYER
I see Ryan put a mega fuse in his 55 LS swap. I like the idea, cheap addition to save investment. My question is, how did he size the fuse? meaning how did he choose what amp fuse to use. Thank you in advance.
Ted
May 15, 2025 at 5:12 AM
RYAN L
  • 273 POSTS
Hey there,
Thank you so much for watching the series!
That was my thinking too. That fuse came with the Painless wiring kit. My thinking was they probably have a good idea on how many amps is right. Also, 175A is way more than basically any car will ever use under normal circumstances. But will pop is there is a large short to ground.
Thank you for using 2CarPros! Good luck on your build!
Best,
Ryan
May 16, 2025 at 4:20 AM
