Mechanical fuel pump to electric fuel pump as easy as possible.
GAVYNH
  • 1986 CHEVROLET SILVERADO
  • V8
Hey I got a 1986 Chevy C-10 and I am attempting to install an electric fuel pump but my knowledge of how to is very minimal. I have heard I need to by separate fittings new hoses and a bunch of other stuff. This is just a little town truck so I am not really looking into putting a bunch of money into for regulators and stuff like that. If anyone is willing to help me step by step of just some tips it would be very appreciated.
Tuesday, December 8th, 2015 AT 5:50 PM
  • 109,724 POSTS
Okay, first you need to understand that electric fuel pumps can produce a lot of pressure. A carburetor can not handle what most will supply. You need to find an electric pump that will produce around 7psi. Once you get it, locate a place on the inside of the frame rail to place it (where the present fuel line goes). You will need to cut the steel fuel line so as to fit the pump within the lines. Once that is done, you will attach the pump on both sides most likely using rubber high pressure fuel line and clamps. Those directions should come with the new pump. Once that is done, you need to provide power to the pump. The power should be switched, meaning only on when the key is in the run position. Again, once you get the power, follow the directions that come with the pump. NOW KEEP THIS IN MIND. Your vehicle doesn't have an automatic shut down in the event of an accident or roll over. This can be dangerous. The pump will not turn off automatically. If there is a fuel leak, it will continue pumping fuel. If there is a fire, it will constantly be fed fuel until power is lost.
I have to ask, why an electric pump when a mechanical is under 20 dollars?
Tuesday, December 8th, 2015 AT 6:19 PM
GAVYNH
Thanks for the quick response that clears it up alot and because I belive the lobe on my cam is bad so the push rod won't push so the mechanical pump work either that or the push rod is broke. And the pump I have is 6.5 psi
Wednesday, December 9th, 2015 AT 8:57 AM
  • 109,724 POSTS
Wednesday, December 9th, 2015 AT 4:07 PM
