I have a 97 chevy s10 2.2 4cyl, the shop I took it too replaced the timing chain, I didn't know what was wrong with it, and my truck had 20# of oil pressure which is enough to run it just fine, and they didn't check the oil pan for plastic pieces, I paid them $300 and was told it was good to go and that they test drove it and it was good, so I left thinking my truck was in perfect condition now, and everything was perfect shifting fine good oil pressure, ran like a top not a thing wrong so i thought, I drove 15 miles, and my oil pressure dropped to zero and something started rattling or "knocking" I pulled over not immediately when this happened, I mean not 5 seconds after it did this and shut it off, I sit there for a minute, started it again, never moved mind you, it was rattling so I shut it off, and checked the oil, perfect to the top of the safe zone, I called them, they sent a wrecker for free, a day or 2 later they call me n tell me the plastic pieces plugged the screen n I need a new oil pump, and that they will have to pull the motor to make sure it didn't hurt the main and rod or whatever, and they will do half the labor for free and that the book calls for 11 hours but they'll do half the labor for free, so another $400, I'm a little irritated but ok go ahead, 4-5 days or so they call me again and tell me that I need a crankshaft and bearings, and it will be $1100, before I took the truck there no knock or rattle and good oil pressure I didn't even make it home before it broke and I've been told not by them but other mechanics that anytime the timing chain has plastic gear coating it should have the pan checked to make sure there are no pieces in there to prevent what happened from happening n they never recommended that or did that, now they are arguing that it wasn't their fault speaking and that they don't know how long ive drove it like that and that the crank shaft and bearings couldn't have been that damaged in 15 miles. Help me on what I should do!
May 22, 2013 at 2:43 PM
