Trouble removing pulley and bolt from crankshaft
AKR44
I have a 1984 Mazda B2000 PU and I am having trouble removing the bolt from the crankshaft so that I can remove the timing chain cover. First, which way is it supposed to turn to loosen, second, do you have suggestions for removing it?
Sep 23, 2007 at 9:04 AM
  • 75,988 POSTS
[quote:8351180fd0="akr44"]I have a 1984 Mazda B2000 PU and I am having trouble removing the bolt from the crankshaft so that I can remove the timing chain cover. First, which way is it supposed to turn to loosen, second, do you have suggestions for removing it?[/quote:8351180fd0]
You have to turn it left/ counterclock wise to loosen it.
NOTE: note the rotation of the crankshaft.
Find correct size deep socket and a small extension 1/2 drive with ratchet, get a short pipe so that you can insert the ratchet in it. brace the pipe properly against the ground or within the engine now crank engine over-this will break it loose without jamming the starter and flywheel to prevent it from moving. This is the fastest way to do it.
Sep 23, 2007 at 9:51 AM
