1987 Mazda B2600 High Idle and Bogging
WFRAVEL
I've got a 1987 Mazda B2600 2.6 L 100,000+ miles. I just got the starter replaced and now I found out that I have a new problem. The engine already idles high but when I go to drive it I cant go faster than 15 mph. It also sputters when I hit the gas as if its being bogged down. Can anyone help?
May 21, 2007 at 12:23 PM
  • 75,988 POSTS
[quote:9e69f2f3f9="wfravel"]I've got a 1987 Mazda B2600 2.6 L 100,000+ miles. I just got the starter replaced and now I found out that I have a new problem. The engine already idles high but when I go to drive it I cant go faster than 15 mph. It also sputters when I hit the gas as if its being bogged down. Can anyone help?[/quote:9e69f2f3f9]
Your choke is probably closing-adjust the opening and fast idle cam.
May 22, 2007 at 10:21 AM
DANCARLSON
  • 50 POSTS
Check your fuel pressure by connecting a fuel pressure guage between the filter and the distribution pipe, you might have to change your fuel filter. Carefully check over your vacuum hoses to make sure that there are no crackes.
May 27, 2007 at 11:27 PM
Suggested Repair
Adjust the choke opening and fast idle cam so the choke is not staying closed. Also check fuel pressure between the filter and distribution pipe, consider replacing the fuel filter, and inspect vacuum hoses for cracks.
Conversation Summary
The owner of a 1987 Mazda B2600 with over 100,000 miles reported a high idle, sputtering under throttle, and inability to exceed about 15 mph after a starter replacement. An expert said the choke was probably closing and recommended adjusting the choke opening and fast idle cam. Another participant suggested checking fuel pressure, possibly replacing the fuel filter, and inspecting vacuum hoses for cracks.
