1989 Mazda Truck Fast Idle Cam won't disengage
1989 MAZDA TRUCK
134,000 MILES • 4 CYL • 2WD • MANUAL
SELAERATION
This trusk starts great and runs great but the fast Idle cam won't disengage unless I move it by hand. Then as soon as I push the accelerator, the fast idle cam engages and won't disengage. Idle is very high cold or hot. Any suggestions?
Feb 28, 2008 at 1:49 AM
MERLIN2021
  • 17,250 POSTS
So this would be a carb model? If so, remove the rivets or loosen the screws holding the choke thermostat, adjust, or at this point, more likely you'll need to replace the bi-metalic spring under the platic cover...and readjust choke! Also if it has a pull off test it, it may not be functional.
Feb 28, 2008 at 4:45 AM
