Mazda Truck Vacuum Hose connection
DAVENWHITTIER
Engine Performance problem
Mazda Truck 4 cyl Two Wheel Drive Manual
I really need your help!
I need a point A to point B on all my hoses. All my manual has to offer is "be careful when you remove them not to get them mixed up" I can't unring that bell.
Any suggestions will be greatly appreciated.
Mar 31, 2009 at 8:19 AM
IMPALASS
  • 3,112 POSTS
Hello –
Well, we can’t make any promises since we don’t know what our manuals say, but we will sure give it a try!
First, I need a little more detailed info on your vehicle.
Please tell me the year, I know it is a Mazda, but I need the exact model, engine size in liter and the 8th digit of your VIN.
Mar 31, 2009 at 9:42 AM
DAVENWHITTIER
vin number: JM2UF2118G0516308
1986 Mazda 4 cylinder pick up truck
Apr 2, 2009 at 4:26 PM
DAVENWHITTIER
It's a model B2000
Thanks
Apr 2, 2009 at 4:27 PM
IMPALASS
  • 3,112 POSTS
Hello –
I want to make sure that you have just the B2000, not the B2000LX, or the B2000 SE-5. Also, is this vehicle in California………..as there are two choices………Federal and California Models and Canada but I assumed you were not in Canada..
Thanks
Apr 3, 2009 at 10:10 AM
DAVENWHITTIER
Is it possible hooking up the vacuum lines could cause a leak in the front end? Started leaking oil pretty heavy after i hooked up the vacuum lines using a diagram off the web.
the supplier for the diagram said althought it comes up under B2200 on https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals that the vacuum systems on mazda b2000 trucks years 1986 and up were the same.
Can I trade my request for a vacuum diagram for help with the oil leak I believe is coming from my front seal. It didn't leak at all until i worked on the vacuum hoses?
Thanks for your timely responses,
Dave
Apr 3, 2009 at 12:02 PM
IMPALASS
  • 3,112 POSTS
Hi Dave
Well, you don’t have to trade; I will gladly give you the vacuum diagram I just need the previous questions answered and may for the oil leak. They were:
I want to make sure that you have just the B2000, not the B2000LX, or the B2000 SE-5. Also, is this vehicle in California………..as there are two choices………Federal and California Models and Canada but I assumed you were not in Canada. AND – please tell me the size of your engine in liter…………I know it is a 4cyl….but what is the liter size………should be on a decal under the hood………..
If you are sure it is from the front seal……….are you………then no, I don’t see how vacuum hoses would do that unless you hit the seal with a screw driver or something. If the car has sat a while the seal may be drying out.
Again, are you sure it is coming from there?
Apr 4, 2009 at 3:24 AM
