mazda b2300
SYOUNKIN
i've got a 97 mazda b2300 that will not stay running. there are no trouble codes ,and i have checked all sensors ,iac ,changed the timing belt because the crank was off 8 cegrees ,and still it won't stay running. if i hold the gas pedal down to try and make it idle it will die down and backfire through the intake then shut off .i'm sure my timing marks are correct it did the same thing before i changed the belt. please help i dont know what else to check.
Apr 19, 2006 at 3:08 AM
TERRYNNA
we have to install a new belt and can not get the iol sprocket gear to line up ther is no mark on it that we can see please help if you can
Aug 9, 2006 at 5:42 AM
SYOUNKIN
i had a mazda with the same problem almost exactly.it ended up being an air flow meter.
Aug 9, 2006 at 10:37 AM
MWHITNEY
  • 63 POSTS
I'm mazda and ase cert. You need to look at spark plugs and wires first
Dec 12, 2006 at 12:55 AM
