i have a 1991 mazda b2200 m/t carbureted. how do you adjust the idle switch at the front of the carb? thanks. armadour1
Aug 28, 2007 at 4:02 AM
Raise engine speed above 2,000 RPM, then gradually decrease it. Voltage should be less than 1.5 volts at 1,000-1,200 RPM and 12 volts at idle. If idle voltage is not 12 volts, turn the adjustment screw until the reading is correct.
The owner of a 1991 Mazda B2200 manual, carbureted truck asked how to adjust the idle switch at the front of the carburetor. The expert advised raising RPM above 2,000, then gradually reducing speed so voltage is under 1.5 volts around 1,000-1,200 RPM and 12 volts at idle, turning the adjustment screw if idle voltage is not 12 volts.
