Headlight Switch
RTATUM
My 1986 B2000, headlight/turn signal will only turn off my headlights when left in the high beam mode (push forward toward the dashboard). Shoud I replace the entire switch or could something else be the problem? How hard is it to replace the switch if this is requried? Thanks for any help you can provide.
Jun 25, 2007 at 9:29 AM
TNALARTRAV
I had that problem with my 1993 B2600. The light switch is in two parts. I believe one is for the turn signal and the other for the headlights. I went to Autozone and they had the switch (the part needed) and that fixed the problem. I had it installed by a Mazda repair shop where I live and he said that Mazda recommends replacing the whole switch but just the part that was causing the problem was sufficient.
If you have a repair manual or enjoy taking apart the steering column, I don't think it was too hard to get to the switch, I just didn't have the time to do it.
Jul 29, 2007 at 6:08 AM
