Where is the door switch on a 2001 B3000?
Nov 4, 2006 at 1:07 AM
The door switch is built into the door latch assembly. Remove the door panel, disconnect the wiring connector, and rotate the switch to remove it. Cleaning may restore operation, but replacement is more likely needed.
The owner of a 2001 Mazda B3000 asked where the door switch is because the door-ajar warning and dome light stay on. A Mazda technician explained that the switch is inside the door latch assembly and is reached by removing the door panel, unplugging the connector, and rotating the switch out. Cleaning might help, but it probably will not.
