92 mazda B2600i pickup
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Return for diagnosis while the warm-running failure is present, with the full history of temporary improvement and failed replacements.
Guidance references and applicability
Source: Original question and visible replies. Owner outcomes are attributed; other participants' experiences are not treated as this owner's repair. Next steps are editorial guidance, not a confirmed diagnosis.
Cosmo..Mazda Tech
Discussion summary
A 1992 B2600i ran normally when cold but faltered after warming up. The owner reported control-unit checks, tune-up work and a new coil. Distributor replacement initially helped, but the same symptoms returned; a mass-airflow-sensor trial had also been unsuccessful.
Reported outcome: No lasting repair was documented. The owner's later update withdrew the apparent success of the distributor replacement.
The initial success report must not be treated as a confirmed final fix. No later measurements or answer to the follow-up question were provided.
