2002 Mazda Truck P1537
95,000 MILES • 4 CYL • 2WD • AUTOMATIC
JUDYWWJD
I failed smog, P1537...aamco wants 400.00 to replace intake manifold runner, I replaced the IAC valve and my check engine light went out but after I restarted it, it came back on. Is there anything else I can do without taking it to aamco? They also wanted 95.00 to replace the switch on the brake cause it wouldn't come out of park after the truck was started more than 2 seconds, but I replaced it myself for 8.99 today and it still didn't work, then I noticed that the 7.5 fuse was missing and replaced that and it worked, so they were going to get me on that one. So now I don't trust them.
May 8, 2009 at 3:18 PM
RACEFAN966
  • 5,029 POSTS
First off is this code correct I can not find it in the data base? Have you had the codes cleared? I would call around to your local parts stores and find one that does a free scan and scan it write down any codes and then have them clear it. get back to me with the codes.
May 9, 2009 at 1:25 AM
