2001 Mazda Truck cant get a brake
2001 MAZDA TRUCK
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERT31757
lost piston on right front caliper and replaced rotors calipers and pads on the front and bled system and can not get a pedal. when you bleed with engine off you get a little pedal but as soon as you start the truck the pedal goes to the floor. i have straight fluid coming from calipers and and at rear wheel s but still have no pedal. please help
Jan 27, 2008 at 10:46 AM
If you're not leaking anywhere
Replace the brake master cylinder its leaking inside and not creating hydraulic pressure.
Jan 29, 2008 at 7:58 AM
