2000 Mazda Truck ABS
43,000 MILES • 4 CYL • FWD • AUTOMATIC
HELP!123
  • 5 POSTS
The ABS light is staying on after the engine starts. That gears will not automatically shift and I can only drive it 10 to 15 mph. The speedodometer and travel odometer will not work. Can anyone tell me what the solution might be?
Apr 17, 2009 at 3:12 AM
HELP!123
  • 5 POSTS
I waited but needed to act quickly. I asked around here where I live and did a little research on the internet. Everything I was told and read pointed to what the mechanic i talked to said. The mechanic was trying to help me save some money by not doing the diagnostic test, $45.00 smackers! The dealership charged more! I have been unemployed and was trying to choose the lesser of two evils. If I did the dealership diagnostic and it was something else I didn't have the money for the repair. So, I took a chance and went with what the mechanic believed. I bought the part and got it installed and it worked out for me. And it cost a lot less! It was the sensor in the rear. So, if your Mazda truck has these tree problems together it is probably the abs sensor in the rear. If this helps you save some money I will be glad.
Apr 17, 2009 at 9:44 AM
