1999 Mazda Truck truck wont run smelled like it had an elec
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
JS450R
  • 5 POSTS
well i was going to pick up a tv and the truck just died and just cranked and cranked. had it towed home put a fuel pump in it i tried to start it but nothing checked all the fuse and my fuel pump relay& RAP moudule fuse was blown?? put the same fuse in it started and ran got to the end of the drive way blew it again ???? im lost point me in a direction and im pretty good at fixing cars this one has me stumpped thanks if any one can help me thanks again
Jan 24, 2008 at 6:15 AM
2CARPRO JACK
  • 11,533 POSTS
I need a model for your truck, Mazda has 7 different ones
Jan 24, 2008 at 11:55 PM
JS450R
  • 5 POSTS
im sorry i feel like a re re um i was doing some of my own (home work ) now what circuit supplies the rap, fuel pump relay. fuel pump, pcm ,and the fuel pump monitor because that might be have a littler to do with it thanks again
Jan 25, 2008 at 4:04 AM
2CARPRO JACK
  • 11,533 POSTS
There arent any single feeds for those, several things use the same main power feed. What fuse # was it 9?
Jan 25, 2008 at 6:41 AM
JS450R
  • 5 POSTS
yea it was fuse number nine 20a fuel pump & RAP module
Jan 25, 2008 at 7:02 AM
2CARPRO JACK
  • 11,533 POSTS
If you replace the fuse again will it run? If you repalced the fuel pump, then I doubt that circuit is the issue. The RAP (remote Anti-theft Personality module) is located at the left rear corner of the cab, not sure if the truck will run with it unplugged, but might want to try it to see if it is waht is causing the fuse to blow. Did you visually inspect he wiring under dash since it smelled like it may have burnt
Jan 25, 2008 at 7:12 AM
JS450R
  • 5 POSTS
yes it runs untill it pops that fuse like 20seconds then it shuts the fuel pump relay off and the smell is coming from that fuse box under the hood you can see the black tarnish where it pops that fuse i think that is the smell im smelling i dont think it runs long enough to catch fire now my door ajar light stays on and sometimes while im driving it chimes could that be related to the rap module? going bad but i will try to un plug it im not sure either if it will run cause the key is programmed to that box right? now even the extended cab is it still located in the left rear conner? or is it in the finder? thank again
Jan 25, 2008 at 7:37 AM
2CARPRO JACK
  • 11,533 POSTS
Have you tried a fuel pump relay? Locator didnt discriminate between x-tra or std cab
Jan 25, 2008 at 7:51 AM
JS450R
  • 5 POSTS
you said that the rap module is located in the left rear conner?( looking at the truck or sitting in it) is it behind the the seat? or do i haft to take all of the pannes off in the left conner. also could it be the GEM ( General Electronics Module ) could that short out and pop the number 9 fuse spot? the rap module is around 180 and i have not a clue what the GEM module is going to cost me i dont want to buy the rap module and not be the problem? thanks again
Jan 28, 2008 at 12:23 PM
