1999 Mazda Truck MISS FIRE
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
HUNT
Problem is truck is miss firieing on #3 cylinder, replaced coil plugs and wires and check compression and its good. After replacing coil plugs and wires still shows weak spark on #1,2,3 on the coil pack. Also haveing same troulble on a ford exploder.
Why would it show weak spark on one side of coil pack?
Mar 21, 2008 at 11:26 AM
MASTERTECHTIM
  • 4,750 POSTS
is it actually misfiring? when you say weak spark, what do you mean? does the misfire go away when driving?
Mar 21, 2008 at 12:04 PM
HUNT
[quote:9999128796="mastertechtim"]is it actually misfiring? when you say weak spark, what do you mean? does the misfire go away when driving?[/quote:9999128796]
yes its actually misfiring, even when driving it is running rough. took a ignition firing tester that test spark through the wire. and it shows weak spark on the 123 and strong spark on 456.
thanks
jeff
Mar 22, 2008 at 9:43 AM
