when I go to start the truck it make a repeated clicking noise until i shut it off. Please help
Apr 11, 2006 at 2:44 AM
TRUCKMAN88
MEMBER
First you should check your battery and the connections on it make sure their clean, see if the battery is dead (do the lights turn on or are they dim?) If your battery checks out fine then it could be a problem in your starter motor (maybe the brushes) have it looked at.
