1996 B2300 check engine
ROSE1960
I just had my truck inspected and a few days later the check engine light came on. I took it to Auto Zone and they said it had to be taken to the dealer it has an issue with the fuel and air mixture? Any ideas? I don't know where to start.
Thanks
Sep 9, 2007 at 12:38 AM
MERLIN2021
  • 17,250 POSTS
If it has a mixture problem the dealer can "flash" the PCM hopefully, and fix your problem. What was the code?
Sep 9, 2007 at 12:47 AM
ROSE1960
The fella at Auto Zone did not give me a code. ON the machine it said that it was a manufactur code and i would have to take it to the deaer...
Sep 9, 2007 at 12:54 AM
ROSE1960
if you don't mind what do you mean flash the PCM?
Sep 9, 2007 at 12:59 AM
MERLIN2021
  • 17,250 POSTS
It means if they need to reset or change the parameters of the computer they have a tool to do it.
Sep 9, 2007 at 1:05 AM
