1995 Mazda Truck Timing chain?
85,000 MILES • 6 CYL • 2WD • MANUAL
DDM00767
Truck B3000 was running fine, no noises, problems, etc. Sudden rattle on highway, we pulled over, it died. Motor is locked, starter was checked, it's fine. Possible timing chain broke? Any other suggestions?
Nov 30, 2008 at 3:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Probably chain or one of the pulleys have failed. Have you checked chain?
Nov 30, 2008 at 5:29 AM
DDM00767
[quote:781f5b9093="bluelightnin6"]Probably chain or one of the pulleys have failed. Have you checked chain?[/quote:781f5b9093]
So far we have eliminated clutch problem, timing chain has just a little slack but not broken. Motor is completely locked up, will not turn any way at all. Truck is in neutral, still locked up. We are in process of removing motor to see what is up. Have never had trouble with it, plenty of oil, no previous noises until death roll. Of course since we have it apart will replace clutch etc and timing chain.
Any other ideas? We just can't figure out why it would lock up while running, normal highway conditions, level ground. Must be just our luck. ;-)
Nov 30, 2008 at 7:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You can remove all the spark plugs and make sure it's not locked with water or gas.. other than that I would believe that you will need to do the teardown to look for internal parts that have failed.
Nov 30, 2008 at 7:29 AM
DDM00767
[quote:8b2da2a7a5="bluelightnin6"]You can remove all the spark plugs and make sure it's not locked with water or gas.. other than that I would believe that you will need to do the teardown to look for internal parts that have failed.[/quote:8b2da2a7a5]
Spark plugs out, oil out and fine, radiator out, clear water. Yep, guess we're going in deep. I thought sure it was the timing chain from the sudden noise, like something breaking but no, it's ok. So looks like something inside motor. Guess we can just hope something we can fix or replace without replacing whole motor.
Nov 30, 2008 at 7:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry that you are having such luck with the engine. If you need any help in tear down, diagnosing, and/or rebuild of engine just post and we will do our best.
Nov 30, 2008 at 7:42 AM
DDM00767
[quote:9e3a731215="bluelightnin6"]Sorry that you are having such luck with the engine. If you need any help in tear down, diagnosing, and/or rebuild of engine just post and we will do our best.[/quote:9e3a731215]
Thanks, let you know what we found tomorrow, shop is closed for the day!
Nov 30, 2008 at 7:44 AM
