1995 Mazda Truck fuel system
130,000 MILES • 4 CYL • 2WD • MANUAL
MAZDAB2300
  • 5 POSTS
I have a 1995 Mazda B2300. It suddenly started acting strange. It will start great when cold. Once it warms up, it revs very high (about 2500 rpms) between shifts. If I push in the clutch and stop, it will take several seconds (15 or so)before the idle finally drops to normal. When I shut it off while it is warm, it is very hard to restart it again. Any ideas? I already replaced the spark plugs and fuel pressure regulator. thank you
Oct 9, 2008 at 1:59 PM
DOCFIXIT
  • 18,828 POSTS
Maybe problem with Idle Speed Conrol motor on throttle body. It is controled by the ECM
Oct 12, 2008 at 8:03 AM
MAZDAB2300
  • 5 POSTS
Is this the same as the idle air control valve?
Oct 12, 2008 at 9:54 AM
MAZDAB2300
  • 5 POSTS
I had it hooked up to an OBD2 reader and it did not come up with any codes either.
Oct 12, 2008 at 9:56 AM
DOCFIXIT
  • 18,828 POSTS
It may not set a code pull it off see if pental is carboned up keeping it from closing air passage off to lower RPMS
Oct 12, 2008 at 10:01 AM
MAZDAB2300
  • 5 POSTS
Is that the same as the idle air control valve?
Oct 12, 2008 at 10:21 AM
DOCFIXIT
  • 18,828 POSTS
Oct 13, 2008 at 12:17 AM
MAZDAB2300
  • 5 POSTS
I will try to clean that or replace it next.
Oct 13, 2008 at 4:12 AM
