1992 Mazda Truck Air conditioner only works on speeds one a
1992 MAZDA TRUCK
136,000 MILES • 4 CYL • 4WD • MANUAL
B2600I 92
my AC has always worked, but today the air works only on speeds one and two, but the fan does not blow on these speeds. The AC button is lit on speeds one and two. When you turn the fan to speeds three and four, the fan runs but light goes out on AC button. In the past when the fan does not run, I change the resistor block which fixes that issue. I have a couple back up resister blocks, but think this may have to do with a relay or something. The engine is a B2600i.
thank you for your help.
Jun 2, 2008 at 2:31 AM
B2600I 92
A new resistor block corrected the problem.
fyi
Jun 3, 2008 at 2:11 AM
