1992 Mazda B2600
1992 MAZDA TRUCK
JSCLOSE
I've changed the fuel tank,pump,filter,ign. coil,ECM and the vehicle has a stalling problem.
Driving down the road the truck will die w/out notice.
I still have "spark" and fuel pressure at the fuel filter.
I need some help, this is driving me nuts!
Aug 5, 2006 at 6:49 AM
HETMANB
I had the exact same problem while driving a toyota a few years back. It ended up being the magnetic pickup coil (which seems to have a different name for each brand of vehicle.. in toyota's case, it was the "igniter" i believe) But, if you've changed the ignition coil already, then perhaps that isnt the solution after all.
Good luck.
Aug 31, 2006 at 1:01 PM
