1991 Mazda B2600 pickup
CHIGNIKGRUNERT
ok, my mazda truck just stopped running one day like someone turned off the key. after that it never ran since. i have changed the distrubutor cap and the ignition coil. i also had the computer sent out to be repaired. but still nothing. its not getting any spark and the spark plugs dont get wet with fuel when the engine is cranked on. also i checked for power going to the spark plugs and it seems power ends right at the distributor cap. i also checked if the fuel pump is working, but was pumping fuel just fine. im all out of ideas and if anyone has any idea what is going on, please get back to me.
Sep 20, 2006 at 2:03 PM
ORIGINALMAZDAWG
remove ur dist. cap and have somebody crank the engine while you watch the rotor. If the rotor does not spin, you more than likely have a broken timing belt, check it out......L8RS!!
Oct 10, 2006 at 1:46 AM
CHIGNIKGRUNERT
yeah the rotor is definetely turning. i actually think its the crank shaft sensor i think. the only problem is im no where near the truck so ill have to get my dad to do all the checking. thanks for your reply.
Oct 10, 2006 at 12:22 PM
