1990 Mazda Truck engine
200,000 MILES • 4 CYL • 2WD • MANUAL
DAVIDKURT
Engine immediately jumps to 2K rpms when started. any more than 4K rpms and the engines chokes ite=self too death literally. Guage max rpm is 6K. Timing has been checked. Compression reads 160 145 145 140 in cyl 1234 respectively. The tester said 2 and 3 come up slowly. changed many parts plugs wires used coil and chips near coil. new starter. previous alternator was bad and i believed fried the battery. replaces with used alternator(tested) and battery. paid large sum too investigate problems. mechanic found blockage in the air manifold.
Mar 25, 2008 at 7:22 AM
  • 75,988 POSTS
Test the idle speed control solenoid and the throttle sensor-also could be a binding throttle plate/cable and vacuum leak
Mar 25, 2008 at 8:02 AM
