1988 Mazda Truck Fuel Pump Relay?????????
MRGOLDWING
Electrical problem
1988 Mazda Truck 4 cyl Two Wheel Drive Automatic 150k miles
1988 B2200 4cyl, auto. Does this truck have a fuel pump relay and if so where? It is not getting any power to the pump. Can I run a hot wire to the pump and bypass the relay?
Thanks
Jan 16, 2008 at 12:55 PM
FISHERMAN
  • 937 POSTS
[quote:6701a3ae7a="mrgoldwing"]Electrical problem
Thanks[/quote:6701a3ae7a]
Hello !!
The Fuel Pump control unit its located under left side of dash.
and its not a good idea to "bypass" the relay because it is controlled by the ECM.
good Luck.
Jan 16, 2008 at 1:04 PM
