1988 Mazda B2200, 139,000 KM,
1988 MAZDA TRUCK
TRISH63
Truck starts and idles good but when under load, (eg. going up hill) starts to cough. If accelerator is held down while going up hill it starts to cough and die. When leaving an intersection or stop sign and accelerator is held down it will also cough and die. Acts like it isn't getting enough fuel. Have replaced fuel filter and fuel pump, spark plugs, plug wires, rotar and cap. PLEASE HELP!
Jan 12, 2007 at 3:21 AM
COSMO
  • 347 POSTS
Try checking the igition coil....feel the bottom of it and see if there is a high level of corrosion on the bottom of the coil and check for any fluid leaking out of hte coil.
Its either that or some sort of fuel probelm.
I take it that it is a 5sp carb engine right?
Cosmo...Mazda TEch
Jan 12, 2007 at 3:37 AM
TRISH63
Thank you for your prompt reply. Yes it is a carburated engine but I am unsure of what 5sp means
Jan 12, 2007 at 3:46 AM
What Cosmo means with the 5sp is-its a 5speed manual transmission.
For your problem, check the acelerator pump on the Carb-when you manually engage the throttle you should see a stream of gas coming from the acc. nozzle
Jan 16, 2007 at 12:42 PM
TRISH63
Thank you to all for responding to my problem. I have since this conversation had a friend look at my truck. After every last dime I put in for all those new parts we have fixed the problem. If you can imagine, after we had replaced the fuel filter, we had to put more gas in because of all the test runs and it seems I ended up with bad gas. It ran very nice when we replaced everything for about 3 days and that was when the problem started again and after hours of cleaning and replacing someone had said to re-check what we had done and low-and-behold the fuel filter was totally plugged. We replaced it again and have had no further problems, geesh...
Jan 17, 2007 at 1:15 AM
