1987 Mazda Truck timing
ZACH NEWKIRK
Engine problem
1987 Mazda Truck 4 cyl Four Wheel Drive Manual just r miles
What are the timing procedures for a b2600 engine. Please include pictures if possible and the more specific the better. Thank you.
Jan 5, 2008 at 6:44 AM
  • 31,937 POSTS
Hi there, Get engine up to temp, unplug cooling fan if electrical, attach timing light to No 1 spark plug set timing by loosing clamp bolt at base of distributor & rotating as required to 7Deg BTDC.
https://images.2carpros.com/forum/automotive_pictures/61395_mazda_timing_1.jpg
Lock distributor clamp, when set. Check idle before timing adjustment 850 RPM and again after any adjustment. Mark (mhpautos)
Jan 5, 2008 at 7:27 AM
