1987 Mazda Truck Ticking Noise
1987 MAZDA TRUCK
WADEBISSELL
Engine problem
1987 Mazda Truck 4 cyl Four Wheel Drive Manual 165K miles
This truck has the non-fuel injected 2.6 liter engine. It sounds like a lifter but since this is an overhead cam engine, i know there are no lifters. I believe there are hydraulic lash adjusters but don't know if they could cause this issue.
The ticking is most pronounced when the season is cold. During this time, the tick is constant but does lessen as the engine warms up. I've tried changing oil viscosities and have noticed a difference but it doesn't go away. I've tried 10W-30, 10W-40, and currently using straight 30W. This last viscosity seems to perform the best and is less noisy. During the summer months, the noise is present during initial warmup but then will go away completely...for the most part. I do hear an occasional tick or two while idling.
Don't know if this matters but the previous owner "de-smogged" the engine and installed a webber carburetor. I'm not fond of this but otherwise, the truck runs well. Also, I have tried oil additives (Power Punch, Marvels Mystery Oil, added a quart of auto trans fluid to clean out what might be lodged somewhere...it was a long shot) but nothing seems to make a difference.
I considered the possibility that the noise might be an exhaust leak from either the exhaust manifold or where the exhaust pipe connects to the manifold. Other than trying to feel around the pipe while idling, I don't know how to check for this. This inspection didn't reveal anything.
I would be interested in a professional opinion and ideas for correcting this. Thank you.
Dec 28, 2007 at 11:43 AM
2CARPRO JACK
  • 11,533 POSTS
Have replaced "lifters" in those before due to ticking.Since oil weight changes th enoise I would reccomend the lifters and the rocker assembly be changed. Where the lifters ride can become worn causing an excess clearance around the lifter
Dec 29, 2007 at 12:17 AM
WADEBISSELL
Thank you for your answer. But can you tell me why it makes such a difference with the seasons? My thinking is that when the engine is at temperature, it's AT temperature. There's isn't enough difference if it's winter time or summer time compared to the temps of the engine so the outside temps shouldn't make any difference.
Oh also, when you say "lifters", do you mean the hydraulic lash adjusters?
Dec 29, 2007 at 1:25 AM
2CARPRO JACK
  • 11,533 POSTS
yes I mean the lash adjusters.Oil is more sensetive to temp than we are.if it gets just a little bit colder, the oil thickens up, opposite of summer which thins it out
Dec 30, 2007 at 12:34 AM
WADEBISSELL
Thank you, Jack. Appreciate the info.
Dec 30, 2007 at 2:19 AM
2CARPRO JACK
  • 11,533 POSTS
You're welcome
Dec 31, 2007 at 12:35 AM
