1986 Mazda Truck mazda b2000 carb prob
1986 MAZDA TRUCK
LAZZIN2002
Engine Performance problem
1986 Mazda Truck Two Wheel Drive Manual 202000 miles
mazda b2000 stalls after it reaches oporating temp and wont start till cool.
Aug 5, 2008 at 9:39 AM
When it stalls out-do below immediately to determine if its a fuel or spark problem
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Aug 5, 2008 at 9:47 AM
LAZZIN2002
thanks for youre info i had already sprayed the carb with carb cleaner and know its a fuel prob.Not shure if its the carb or what.
But again thank very much.
Aug 6, 2008 at 9:42 AM
Check the fuel pump pressure-this will point you to a failed fuel pump before you start blaming the carb or injection unit-If its a carb could be that the choke plate is not opening-remove aircleaner and look in there-when engine is fully warmed up it should be wide open-
Aug 6, 2008 at 9:48 AM
LAZZIN2002
Thats great advice i will start there and see what happens.It is indeed a carb and it my just be the choke.
Love this site and thanks for the help.
Aug 9, 2008 at 2:03 PM
MULE50
i am having the same prob with mine and it has 250,000 on it. there should be a white wiring harness on the front of ur carb. it is one of the solenoids that is wired in it i have not found which yet. u can bypass them by using a wire from the positive on the ignition solenoid to the positve on the battery. dont leave in just touch it to the battery a couple times it will click the solenoids and it should start back up. do this after u warm it up
Oct 22, 2009 at 10:02 AM
