1986 Mazda Truck b2000....Carb problem and running rough
300,000 MILES • 4 CYL • 2WD • MANUAL
BUDLACK
I just bought this truck and it starts great when cold, but after warm, the secondary carb bowl fills with gas and floods bad....I have to start it with the pedal to the floor......then has idle problems......also......jst replaced needle and seat and checked the float, seems ok..
thoguhts anyone..........thanks a bunch
May 12, 2010 at 12:48 PM
  • 75,988 POSTS
I have to start it with the pedal to the floor......Doing this helps to clear out the flood with more incoming air. The carb has an internal leak-possibly the float has a pin leak drowning the float bowl.
May 12, 2010 at 12:58 PM
BUDLACK
I don't think the float is leaky, there was no liquid in it when I took it apart.......any other thoughts
May 12, 2010 at 1:16 PM
  • 75,988 POSTS
Your problem is coming from the carb or you have an excessive fuel pressure
May 12, 2010 at 4:26 PM
