2005 Mazda Tribute misfires
2005 MAZDA TRIBUTE
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
PIGLET2705
My mazda continues to misfire. We have changed all coils and spark plugs. We have even replaced the fuel injector. Do you have an idea of what could keep causing this?
Feb 7, 2010 at 5:11 AM
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Feb 7, 2010 at 5:55 AM
