2004 Mazda Tribute Idling rough
2004 MAZDA TRIBUTE
68,500 MILES • 6 CYL • FWD • AUTOMATIC
DONTMISSYOURWATER88
Check engine light came on, and since then the car has been idling rough. When stopped but still in drive (for example at a stop light) the RPM gauge will bounce around a little bit between as I can hear the engine running a little rough. When the car is in park the RPM gauge will sometimes go up to 2000 when it usually idles around 500.
Sep 21, 2008 at 8:57 AM
Check the PCV and EGR valves to include the idle air control valve/throttle position sensor.
Sep 21, 2008 at 9:34 AM
