There are a number of things that will cause low power up hills, but we need to start with this guide that will help cover the basic items.
https://youtu.be/U1RoG3I-Oww
Basically, this is most likely a restriction in the exhaust, or the vehicle is not knowing how much air is coming in which messes up the air fuel ratio. Or the air fuel is off due to a fuel pump issue.
Let's start by checking the fuel pressure when this happens.
Next item would be to clean the air flow sensor. This is basically a Ford so you should have the MAF shown in this guide.
https://www.2carpros.com/articles/mass-air-flow-service
Lastly this may be a restriction so we should remove the up steam o2 sensors and see if you get a little better performance.
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Please run through all this info and let us know what you find.
Thanks
Feb 6, 2022 at 9:11 PM
