2002 Mazda Tribute Fuel Pump
80,327 MILES • 6 CYL • 4WD • AUTOMATIC
PYTHONT
The check engine light came on last week and I took it to Autozone. The code was P1450 which the probable cause was Evap purge solenoid or fuel cap off or damaged. I drove it for 3 days without any problems but after running an errand it finally would not start (engine cranks normal). I tried to check what was causing the no start found that the fuel pump was not working. There is no current to the fuel pump and no current to the reset switch. There is current to the fuse and relay for the fuel pump. Am I correct to think my problem is the ECM? Any input would be appreciated.
Oct 20, 2010 at 2:18 PM
  • 75,988 POSTS
If you have power to the fuse and fuel pump relay-the computer fuel pump driver circuit is defective or the lite blue and orange wire is open
Oct 20, 2010 at 6:31 PM
