Running lights not working Need some 411
LEDGE2EDGE
  • 9 POSTS
[img:2999cefb18]http://www.2carpros.com/forum/automotive_pictures/119025_rx7_2.jpg[/img:2999cefb18]
This is my 1986 Rx7, as you can see it is being modified.
At this point in time i have ran into a stick in the mud.
The problem is I have no running lights, I have replaced the fuses all of em. also changed all the bulbs too inside and outside bulbs. But still no fix yet.
I have brake light and turn signals, also hazard lights work too.
So what am I missing, I have thought that is could be a bad switch but am hoping that i am wrong.
Anyone have this problem before?
Nov 17, 2007 at 12:21 PM
FISHERMAN
  • 937 POSTS
Hello !! I think that your problem its a single wire... follow it all the way to the switch it could be bad at some point ( RED AND BLACK WIRE ) Also check the BLACK wire (ground) you can check the switch, if good should show output on the red and black wire positive (+) Here the wire schematic:
https://images.2carpros.com/forum/automotive_pictures/576_Mazda_RX7_1.jpg
Good Luck and remember: all donations are really appreciate! (if possible)
Nov 17, 2007 at 3:50 PM
LEDGE2EDGE
  • 9 POSTS
Thanks i thought it might be that cause i also forgot to say that i have all my dash lights too. But i will see if i can find this evil wire in that small area Again Thanks for your help.
https://images.2carpros.com/forum/automotive_pictures/119025_rx7_6.jpg
Nov 17, 2007 at 4:22 PM
FISHERMAN
  • 937 POSTS
Hey... if you need the complete schematic of the lighting let me know!!
that wire "feeds" the dashboard lights also.
good Luck!
Nov 18, 2007 at 1:50 AM
LEDGE2EDGE
  • 9 POSTS
Well at the moment my dash lights work. so I am thinking that the switch might be the problem. so far i am checking my parts car down in the Colorado springs. But i will let you know if i need that sked for the wiring. Thanks much
https://images.2carpros.com/forum/automotive_pictures/119025_rx7_7.jpg
Nov 18, 2007 at 4:15 AM
FISHERMAN
  • 937 POSTS
OK Let me know..
Good Luck!
Nov 18, 2007 at 4:20 AM
