1987 Mazda RX-7 Overheating
CHRIS TIELL
  • 8 POSTS
I am having problems with the car over heating. I have replaced the thermostat, temperature sensor, checked fluids and fans work properly. I am stuck on what else the problem could be. Any suggestions????? PLEASE let me know. Thanks
Jan 9, 2006 at 10:21 AM
COSMO
  • 347 POSTS
I would tend to suspect a faulty clutch in the cooling fan
Cosmo..Mazda Tech
Jan 9, 2006 at 1:25 PM
CHRIS TIELL
  • 8 POSTS
Thanks! You are the second person that suggested that. I will try it and see if it works... I'll let ya know!
Jan 10, 2006 at 1:59 PM
Suggested Repair
Inspect and replace the cooling fan clutch if faulty, as a failed fan clutch is the suspected cause of the overheating.
Conversation Summary
The owner of a 1987 Mazda RX-7 reported overheating after replacing the thermostat and temperature sensor, checking fluids, and confirming the fans operate. An expert suspected a faulty cooling fan clutch, and the owner said they would try that suggestion.
