1981 Mazda RX-7 Excessive Oil Burn
'81 MAZDA RX-7
I have a 1981 Mazda Rx-7, its got a lil over 160,000 i believe. It's a 1.1L 12A Rotary engine, The question I have is that the engine burns oil excessively and this didnt start happening uintil i got back home from a trip i took in the car. I know it is probably the seals or O-rings but i know if it were the seals the Spark Plugs would be Oil Fouled and wet, but thats not the car, they have a lot of Carbon deposit on them but thats it. other than that I just need to know if it could be anything else or what the problem is and how to go about fixing it. Thank you.[img:006679a29c]http://www.2carpros.com/forum/automotive_pictures/58805_1981_MAZDA_RX7_1.jpg[/img:006679a29c]
Feb 11, 2007 at 8:15 AM
COSMO
  • 347 POSTS
Well there is a chance that the oil metering pump has failed or is stuck wide open.
This is the little pump on the front of the motor near the crank pulley with 4 rubber/plastic lines coming out of it.
Cosmo...Mazda TEch
Feb 11, 2007 at 9:43 PM
Suggested Repair
Inspect the oil metering pump on the front of the engine near the crank pulley (the unit with four rubber or plastic lines). It may have failed or stuck wide open and be feeding too much oil.
Conversation Summary
The owner of a 1981 Mazda RX-7 with a 12A rotary reports excessive oil burning that began after a trip. The spark plugs have carbon deposits but are not oil-fouled, so the owner doubts apex seals. The expert says the oil metering pump may have failed or stuck wide open.
