91 mazda rx7 dies
TIMOTHYBRTT
91 mazda rx7, auto, non turbo, 120,000 miles. The car starts up good. runs for about ten minutes, sometimes runs fine, sometimes with loping idle. After car shuts down, (on it's own) I get no injector pulse. Some times I will see a spike on my tester but that's it. Starts the same way every day. Please help. Thanks, Tim
Oct 7, 2007 at 12:31 AM
LEDGE2EDGE
  • 9 POSTS
Now have you disconnected your injectors, then reconnect them to see if it was a bad connection. also? when the last time your changed your fuel filter? also might have a fuel pump that is dying on ya. " or someone put a marble in your tank " But try the injector connections first.
https://images.2carpros.com/forum/automotive_pictures/119025_rx7_5.jpg
Nov 17, 2007 at 3:32 PM
