1999 Mazda RX7 battery probalems
1999 MAZDA RX7
195,000 MILES • 4 CYL • FWD • AUTOMATIC
WANT2WORK209
MY car battery keeps dying i replaced my alternator and just got a new batt on fri on i't sun and it was dead this moring. I tested the alt when the car is running i'm getting 13.5v so i'm assuming the alt is working i'm out of ideas and money
Jul 4, 2010 at 3:04 PM
CARADIODOC
  • 34,321 POSTS
Hi want2work209. Welcome to the forum. 13.5 volts is not ideal but it should be enough to charge the battery enough to start the engine. You might find the voltage creeping up as the battery becomes charged. It should be between 13.75 and 14.75 volts.
If you can drive all day with no problems, then the battery is dead the next morning, look for something not turning off and draining the battery. A glove box light, trunk light, vanity mirror light, and cell phone charger are common causes.
caradiodoc
Jul 4, 2010 at 3:41 PM
