1994 Mazda RX7 smoking
ETHAN56
Engine Performance problem
1994 Mazda RX7 4 cyl Automatic
on my rx 7 when i start the engine it really smokes badly and willnot stop. the engine has about 30,00 miles on rebuilt and run good and sounds good just smokes like hell..Harold
Oct 8, 2009 at 3:12 PM
JEEPFAN
  • 135 POSTS
is it white smoke or black smoke?
Oct 8, 2009 at 3:32 PM
ETHAN56
it is white smoke and its very bad...
Nov 21, 2009 at 4:03 PM
JEEPFAN
  • 135 POSTS
when you got white smoke that means youve got oil burning either youve got some bad valves or your rings are wore out its gonna take some work to rectify the problem
Nov 29, 2009 at 11:17 AM
SLOBEACHBOY
  • 10 POSTS
[quote:4ef16e5fd4="ethan56"]Engine Performance problem
on my rx 7 when i start the engine it really smokes badly and willnot stop. the engine has about 30,00 miles on rebuilt and run good and sounds good just smokes like hell..Harold[/quote:4ef16e5fd4]
If there is that much white smoke then you probably have an O-ring leak which is allowing engine coolant to leak into the combustion chambers. If this is the case you will have to rebuild the engine. By the way a rotary engine has no valves and no piston rings so the only way for excess oil to get into the combustion chamber is if its leaking from the oil injectors when the engine is off. A bad oil seal in the turbochargers could also cause oil smoke. Still it sounds like O-rings to me. Check to see if any coolant is missing and see if there is any oily soot floating on top of the coolant. If it is an O-ring leak the smoke will tend to be worse when you first start the car up and then gradually lessen as the car warms up.
Feb 5, 2010 at 6:35 PM
