1994 Mazda RX7 broken down
BOSTONPSYCHO
Engine Performance problem
1994 Mazda RX7 Two Wheel Drive Manual 72 miles
i hav a 1994 rx7 efini. 72k, i brought it working fine but after 3 weeks it wudnt start, then after leavin it a while it started but ran like a bag of s****, misfiring and wudnt rev up properly, then after a few days of running like that it wudnt strike up agen, it nearly doe,s it tries to start but jus wont make it, that was in february an it still wont start. any advice?
Aug 19, 2008 at 7:03 AM
GDOWNS
You need to check the engine codes in the ECU to find out what is malfunctioning. You can google Check Engine Light Codes or go to www.fd3s.net/engine_codes.html
This should be at least a first step in figuring out what is wrong.
Nov 27, 2008 at 8:06 AM
